주요 콘텐츠로 건너뛰기
HomePod Mini speaker Replacement
필요한 것
    • turn homepod mini upside down
    • peel back the foot cover
    • carefully cut the fabric mesh using the fabric scissors
    • be very careful not to scratch the delicate glass surface on top
    • unscrew the 4 torx screws on the bottom near the speaker holes
    • carefully seperate the top and middle sections from the homepod mini
    • be very careful when separating as there are cables connected to the motherboard as well as the speakers
    • carefully unplug all the cables connected to the motherboard
    • carefully separate the middle section of the homepod mini
    • carefully remove the speaker driver from the bottom part of the homepod mini
    • be very careful not to damage the delicate ribbon cable below the driver
    • remove the speaker driver
    • carefully remove the cables connecting to the driver being careful not to damage it
결론
776831
회원 가입일: 06/10/21
1,095 평판
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 79
전체 시간: 306
