주요 콘텐츠로 건너뛰기
Homedics UHE-CMP15 Charging Cable Cleaning
필요한 것
  1. Homedics UHE-CMP15 Charging Cable Cleaning, Homedics UHE-CMP15 Charging Cable Cleaning: 1 단계, 이미지 2개 중 1개 Homedics UHE-CMP15 Charging Cable Cleaning, Homedics UHE-CMP15 Charging Cable Cleaning: 1 단계, 이미지 2개 중 2개
    • Check the USB port/both ends of the charging cable for dust or grime buildup.
  2. Homedics UHE-CMP15 Charging Cable Cleaning: 2 단계, 이미지 2개 중 1개 Homedics UHE-CMP15 Charging Cable Cleaning: 2 단계, 이미지 2개 중 2개
    • Clear out any buildup carefully with a plastic tool, never metal.
    • Gently rub the plastic tool of choice along the charging port and remove and dust that may have built up over time.
    • Try the charger again, you should see a red LED indicator if the device is charging.
  3. Homedics UHE-CMP15 Charging Cable Cleaning: 3 단계, 이미지 1개 중 1개
    • A red light should appear above the charging port when plugged in, if it does not then the charging cable should be replaced.
    • Purchase a replacement type-c charger or use another charger you already own to test again.
    • If this does not resolve the issue then the battery may be dead, or there is some other issue.
결론
If this guide does not solve your charging problem, check out the battery replacement guide instead.
작성자
3다른 기여자 명과 함께
Kade Betterton
회원 가입일: 10/30/23
267 평판
안내서 2개를 작성함
UMass Dartmouth, Team 3-6, Konn Fall 2023 UMass Dartmouth, Team 3-6, Konn Fall 2023 회원
UMASSD-KONN-F23S3G6
4 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 126
