주요 콘텐츠로 건너뛰기
Homedics UHE-CMP15 Placement
  1. Homedics UHE-CMP15 Placement, Homedics UHE-CMP15 Placement: 1 단계, 이미지 2개 중 1개 Homedics UHE-CMP15 Placement, Homedics UHE-CMP15 Placement: 1 단계, 이미지 2개 중 2개
    • Move the device off of it's current surface.
  2. Homedics UHE-CMP15 Placement: 2 단계, 이미지 1개 중 1개
    • Check the water tank for any damage that may have occurred during washing.
  3. Homedics UHE-CMP15 Placement: 3 단계, 이미지 1개 중 1개
    • Take a look at the sensor to make sure there is no obstruction or blockage that may have occurred from the minerals in the water.
  4. Homedics UHE-CMP15 Placement: 4 단계, 이미지 1개 중 1개
    • If there is, try using vinegar to decalcify the minerals in the water to clear out the blockage.
결론
작성자
3다른 기여자 명과 함께
Dylan
회원 가입일: 10/30/23
337 평판
안내서 3개를 작성함
UMass Dartmouth, Team 3-6, Konn Fall 2023 UMass Dartmouth, Team 3-6, Konn Fall 2023 회원
UMASSD-KONN-F23S3G6
4 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 131
