주요 콘텐츠로 건너뛰기
Homelite UT44172 Operating Switch Replacement
필요한 것
  1. Homelite UT44172 Operating Switch Replacement, Opening Device: 1 단계, 이미지 1/1
    • Use a Philips-head screwdriver to remove the six, 15 mm screws from the casing.
  2. Homelite UT44172 Operating Switch Replacement, Remove Faceplate: 2 단계, 이미지 1/1
    • Remove the faceplate from the main body of the device, lift it and expose the inner mechanisms.
  3. Homelite UT44172 Operating Switch Replacement, Switch Removal: 3 단계, 이미지 1/2 Homelite UT44172 Operating Switch Replacement, Switch Removal: 3 단계, 이미지 2/2
    • Locate and remove the operating switch from the device.
  4. Homelite UT44172 Operating Switch Replacement, Spring Replacement: 4 단계, 이미지 1/1
    • Replace the spring if it is deformed or broken.
    • Be careful that the wires do not get caught in the spring when replacing it.
결론
Adam soto
회원 가입일: 01/30/15
301 평판
안내서 3개 작성하였습니다
USF Tampa, Team 17-5, Watkins Winter 2015 USF Tampa, Team 17-5, Watkins Winter 2015 회원
USFT-WATKINS-W15S17G5
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 8
전체 시간: 257
