주요 콘텐츠로 건너뛰기
Homelite UT44172 Plastic Casing Replacement
필요한 것
  1. Homelite UT44172 Plastic Casing Replacement, Opening Device: 1 단계, 이미지 1개 중 1개
    • Remove the six 15 mm screws from the shear using a Phillips #2 screwdriver.
  2. Homelite UT44172 Plastic Casing Replacement, Remove Faceplate: 2 단계, 이미지 2개 중 1개 Homelite UT44172 Plastic Casing Replacement, Remove Faceplate: 2 단계, 이미지 2개 중 2개
    • Pull the faceplate away from the body of the device and replace it with the new faceplate.
    • Potential for device damage: Be sure to take caution of loose wires during the replacement process.
    • If the plate with the screw sockets was replaced, the wires will need to be put back into the the depressions on the new plate for the device to be closed up properly. See photo with the blades on the right for proper wire placement.
결론
작성자
5다른 기여자 명과 함께
Adam soto
회원 가입일: 01/30/15
301 평판
안내서 3개를 작성함
USF Tampa, Team 17-5, Watkins Winter 2015 USF Tampa, Team 17-5, Watkins Winter 2015 회원
USFT-WATKINS-W15S17G5
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 3
전체 시간: 263
