주요 콘텐츠로 건너뛰기
Homelite UT44172 Safety Switch Replacement
필요한 것
  1. Homelite UT44172 Safety Switch Replacement, Opening the device: 1 단계, 이미지 1개 중 1개
    • Remove the six 1.5 cm screws marked on the picture from the plastic casing with a Phillips #2 screwdriver.
  2. Homelite UT44172 Safety Switch Replacement, Remove Faceplate: 2 단계, 이미지 1개 중 1개
    • Remove the faceplate to expose the inner mechanisms.
  3. Homelite UT44172 Safety Switch Replacement, Switch Removal: 3 단계, 이미지 3개 중 1개 Homelite UT44172 Safety Switch Replacement, Switch Removal: 3 단계, 이미지 3개 중 2개 Homelite UT44172 Safety Switch Replacement, Switch Removal: 3 단계, 이미지 3개 중 3개
    • Remove the safety switch by pulling it away from the body of device.
    • Be careful not to lose the spring, which is under pressure and may fly out during removal.
  4. Homelite UT44172 Safety Switch Replacement, Spring Replacement: 4 단계, 이미지 1개 중 1개
    • Inspect both the spring and the switch to see if either is deformed or damaged. If so, replace the damaged part with a new part.
    • During reassembly, gently move the inner wires out of the way so they do not get caught in the spring.
결론
작성자
6다른 기여자 명과 함께
Daniel Endericavillacis
회원 가입일: 01/25/15
101 평판
안내서 1개를 작성함
USF Tampa, Team 17-5, Watkins Winter 2015 USF Tampa, Team 17-5, Watkins Winter 2015 회원
USFT-WATKINS-W15S17G5
3 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 375
