주요 콘텐츠로 건너뛰기
Honda CRF250L Exhaust Replacement
필요한 것
  1. Honda CRF250L Exhaust Replacement, Honda CRF250L Exhaust: 1 단계, 이미지 1/3 Honda CRF250L Exhaust Replacement, Honda CRF250L Exhaust: 1 단계, 이미지 2/3 Honda CRF250L Exhaust Replacement, Honda CRF250L Exhaust: 1 단계, 이미지 3/3
    • Take off the existing exhaust.
    • Remove the external hex bolt by the header with the 1/2" socket.
    • Then, remove the internal hex socket bolt by the exhaust with the 6mm Allen wrench.
    • When unscrewing the bolt by the exhaust, make sure to hold the nut stationary with the 1/2" open-ended wrench.
  2. Honda CRF250L Exhaust Replacement: 2 단계, 이미지 1/1
    • Slide the pipe into the the exhaust.
    • The pipe should curve downward.
  3. Honda CRF250L Exhaust Replacement: 3 단계, 이미지 1/2 Honda CRF250L Exhaust Replacement: 3 단계, 이미지 2/2
    • Hook the spring on to one of the slots that is welded on the pipe and exhaust.
    • Then, expand the spring to hook around the opposing slot using the spring hook.
  4. Honda CRF250L Exhaust Replacement: 4 단계, 이미지 1/1
    • Slide the clamp over the end of the pipe.
    • Make sure the bolt is stationed on top to tighten later.
  5. Honda CRF250L Exhaust Replacement: 5 단계, 이미지 1/1
    • Slide the mount over the exhaust.
  6. Honda CRF250L Exhaust Replacement: 6 단계, 이미지 1/1
    • Slide the new exhaust onto the header.
    • The exhaust should curve upward.
  7. Honda CRF250L Exhaust Replacement: 7 단계, 이미지 1/2 Honda CRF250L Exhaust Replacement: 7 단계, 이미지 2/2
    • Make sure that the mount is positioned to allow all holes to line up.
    • Insert the internal hex socket bolt.
  8. Honda CRF250L Exhaust Replacement: 8 단계, 이미지 1/3 Honda CRF250L Exhaust Replacement: 8 단계, 이미지 2/3 Honda CRF250L Exhaust Replacement: 8 단계, 이미지 3/3
    • Insert the bolt attached to the mount.
    • Install the nut to the backside of the internal hex socket bolt.
    • Tighten the internal hex socket bolt using the 6mm Allen wrench.
    • Keep the nut stationary using the 1/2" open-ended wrench.
  9. Honda CRF250L Exhaust Replacement: 9 단계, 이미지 1/1
    • Tighten the clamp.
    • Tighten the internal hex socket bolt on the clamp using the 6mm Allen wrench.
결론
To reassemble your stock exhaust, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Brennen Ashford
회원 가입일: 09/15/20
196 평판
안내서 1개 작성함
University of Memphis, Team S2-G8, Willis Fall 2020 University of Memphis, Team S2-G8, Willis Fall 2020 회원
UM-WILLIS-F20S2G8
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 12
30일 전: 78
전체 시간: 1,347
