주요 콘텐츠로 건너뛰기
Honda FC600 Tiller Throttle Lever Replacement
필요한 것
  1. Honda FC600 Tiller Throttle Lever Replacement, Remove the Spark Plug Cap: 1 단계, 이미지 1/3 Honda FC600 Tiller Throttle Lever Replacement, Remove the Spark Plug Cap: 1 단계, 이미지 2/3 Honda FC600 Tiller Throttle Lever Replacement, Remove the Spark Plug Cap: 1 단계, 이미지 3/3
    • Before you begin, it's important that you completely cut power to the tiller by disconnecting the spark plug. This will prevent the engine from accidentally starting up while you're working on the tiller.
    • Grab the spark plug cap and pull it straight out to disconnect the spark plug from the engine.
  2. Honda FC600 Tiller Throttle Lever Replacement, Preparation: 2 단계, 이미지 1/2 Honda FC600 Tiller Throttle Lever Replacement, Preparation: 2 단계, 이미지 2/2
    • Push the throttle lever all the way down.
  3. Honda FC600 Tiller Throttle Lever Replacement, Remove the Throttle Lever: 3 단계, 이미지 1/1
    • Remove the 23 mm-long Phillips #2 screw securing the throttle lever to the handlebar.
    • This screw is accompanied by a square nut. Be sure to retain it for reassembly.
  4. Honda FC600 Tiller Throttle Lever Replacement, Remove the Small Throttle Cable Clip: 4 단계, 이미지 1/2 Honda FC600 Tiller Throttle Lever Replacement, Remove the Small Throttle Cable Clip: 4 단계, 이미지 2/2
    • Use a pair of needle-nose pliers to remove the small clip attached to the throttle cable.
  5. Honda FC600 Tiller Throttle Lever Replacement, Remove the Throttle Cable: 5 단계, 이미지 1/2 Honda FC600 Tiller Throttle Lever Replacement, Remove the Throttle Cable: 5 단계, 이미지 2/2
    • Grab the open end of the throttle cable and pull it out of the throttle lever to free it from its recess.
  6. Honda FC600 Tiller Throttle Lever Replacement: 6 단계, 이미지 1/3 Honda FC600 Tiller Throttle Lever Replacement: 6 단계, 이미지 2/3 Honda FC600 Tiller Throttle Lever Replacement: 6 단계, 이미지 3/3
    • Continue to lift the throttle cable out of the throttle lever, making sure it clears the openings in the recess.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Craig Lloyd
회원 가입일: 02/10/16
35,418 평판
안내서 82개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 781
