소개
Follow this guide to replace a broken throttle lever on the Honda FC600 tiller.
필요한 것
Grab the spark plug cap and pull it straight out to disconnect the spark plug from the engine.
Remove the 23 mm-long Phillips #2 screw securing the throttle lever to the handlebar.
Use a pair of needle-nose pliers to remove the small clip attached to the throttle cable.
Grab the open end of the throttle cable and pull it out of the throttle lever to free it from its recess.
다른 한 분이 해당 안내서를 완성하였습니다.
