주요 콘텐츠로 건너뛰기
Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement
필요한 것
  1. Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Disconnect the spark plug: 1 단계, 이미지 1/2 Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Disconnect the spark plug: 1 단계, 이미지 2/2
    • Before you begin, make sure the engine is switched off and cool to the touch.
    • Pull the spark plug connector straight off of the spark plug.
  2. Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Remove the air filter: 2 단계, 이미지 1/2 Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Remove the air filter: 2 단계, 이미지 2/2
    • Push down on the two tabs at the top of the air filter cover.
    • With the two tabs depressed, swing the top of the cover down.
    • Remove the cover.
  3. Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement: 3 단계, 이미지 1/1
    • Pull the air filter out of the housing and remove it.
  4. Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Unscrew the air cleaner housing: 4 단계, 이미지 1/1
    • Use an 8 mm socket to remove the following fasteners securing the air cleaner housing:
    • Two silver nuts
    • One black bolt
  5. Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Disconnect the breather tubes: 5 단계, 이미지 1/2 Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Disconnect the breather tubes: 5 단계, 이미지 2/2
    • Slide the pink breather tube out of its clip on the back of the air cleaner housing.
  6. Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement: 6 단계, 이미지 1/3 Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement: 6 단계, 이미지 2/3 Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement: 6 단계, 이미지 3/3
    • Use a flathead screwdriver to gently pry the black breather tube off of its connector on the back of the air cleaner housing.
  7. Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Remove the air cleaner housing: 7 단계, 이미지 1/3 Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Remove the air cleaner housing: 7 단계, 이미지 2/3 Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Remove the air cleaner housing: 7 단계, 이미지 3/3
    • Hold the black carburetor hose in place and rotate the air cleaner housing clockwise until you can slide the hose out of its slot on the air cleaner housing.
    • Remove the air cleaner housing.
  8. Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Remove the air cleaner gasket: 8 단계, 이미지 1/1
    • Remove the air cleaner gasket 17228-Z0G-000.
    • This gasket can be replaced as part of the carburetor service kit.
  9. Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Disconnect the carburetor: 9 단계, 이미지 1/3 Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Disconnect the carburetor: 9 단계, 이미지 2/3 Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Disconnect the carburetor: 9 단계, 이미지 3/3
    • Use a pair of pliers to pinch the tabs on the carburetor fuel hose clamp together, then slide the hose clamp about an inch down the fuel hose.
    • Pull the fuel hose straight down to slide it off of the carburetor's hose connector.
  10. Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement: 10 단계, 이미지 1/2 Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement: 10 단계, 이미지 2/2
    • Slide the carburetor to the end of its bracket.
    • The carburetor is still connected to the tiller, so don't try to remove it. Just slide it out until it stops.
  11. Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement: 11 단계, 이미지 1/2 Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement: 11 단계, 이미지 2/2
    • Lift the choke rod out of its hole on the the choke adjuster.
  12. Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement: 12 단계, 이미지 1/3 Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement: 12 단계, 이미지 2/3 Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement: 12 단계, 이미지 3/3
    • Rotate the small clip holding the governor rod on the governor arm clockwise.
    • With the clip out of the way, slide the governor rod out of the governor arm.
  13. Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement: 13 단계, 이미지 1/1
    • Remove the governor spring from the carburetor.
  14. Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Remove the carburetor: 14 단계, 이미지 1/3 Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Remove the carburetor: 14 단계, 이미지 2/3 Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Remove the carburetor: 14 단계, 이미지 3/3
    • Slide the carburetor off of its bracket and remove it.
  15. Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Remove the carburetor gasket: 15 단계, 이미지 1/2 Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Remove the carburetor gasket: 15 단계, 이미지 2/2
    • Slide the carburetor gasket 16221-ZG0-801 off of the carburetor bracket and remove it.
  16. Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Remove the carburetor bracket: 16 단계, 이미지 1/1
    • Use a Phillips #2 screwdriver to remove the two screws securing the carburetor bracket.
  17. Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement: 17 단계, 이미지 1/1
    • Remove the carburetor bracket, along with the carburetor nozzle and insulator plate.
  18. Honda Light Duty Tiller F220K1AT715492 Carburetor Replacement, Remove the insulator gasket: 18 단계, 이미지 1/1
    • Remove the insulator gasket 16212-ZM7-000.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Adam O'Camb
회원 가입일: 04/11/15
196,116 평판
안내서 416개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 13
7일 전: 54
30일 전: 224
전체 시간: 3,968
