소개
Prerequisite only! This guide shows how to remove or replace the inner belt cover in a Honda FRC800K1A Rear Tine Tiller.
필요한 것
Firmly grip the base of the connector and pull it away from the spark plug to disconnect it.
Use a 14 mm socket to remove the bolt securing the outer belt cover.
Pull the tine engagement lever to put belt tension on the transmission pulley.
With the belt taut, use a 12 mm socket to loosen the transmission pulley bolt without fully removing it.
Push the V-belt towards the transmission pulley to release tension.
Slip the V-belt off of the groove in the pulley.
Use a 12 mm socket to remove the two bolts securing the belt guides to the inner belt cover.
Use a 10 mm socket to remove the bolt securing the inner belt cover to the frame.
Use a 14 mm socket to loosen the two bolts securing the guard to the frame.
These bolts have corresponding 14 mm nuts on their opposite ends. You will need to keep the bolts steady with a wrench or socket for the nuts to become loose.
Remove both nuts, but do not remove the bolts yet.
Use a 12 mm socket to remove the motor and transmission pulley bolts.
Hold the pulleys steady to more easily remove the bolts.
Pull the transmission pulley straight off of the splined shaft to remove.
Use snap ring pliers to remove the snap ring securing the tensioner pulley to its shaft.
Use needle nose pliers to remove the three wire clips securing various cables to the back of the inner belt cover.
Pull the inner belt cover clear of the motor and transmission shafts.
Remove the inner belt cover.
