소개
This guide shows how to remove and replace the V-Belt on a Honda FRC800K1A Rear Tine Tiller.
필요한 것
Firmly grip the base of the connector and pull it away from the spark plug to disconnect it.
Use a 14 mm socket to remove the bolt securing the outer belt cover.
Push the V-belt towards the transmission pulley to release tension.
Slip the V-belt off of the groove in the pulley.
다른 한 분이 해당 안내서를 완성하였습니다.
