소개
Some soldering will be required in order to complete the speaker replacement.
Remove the battery cover and take the battery out.
Unless you want a quick pick-me-up, in which case feel free to leave it in and get shocked.
Unscrew the four corner screws using a phillips #0 screw driver to remove the back cover.
While the screws are recessed deep into the cover and difficult to see, 2-4 turns will easily release them.
Connect the battery and turn the power on to test proper connection of the new speaker.
Some static is fine, this is the natural sound of the amp.
Careful not to touch any of the metal components inside while temporarily testing the connection.
해당 안내서 퍼가기
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
미리보기
