주요 콘텐츠로 건너뛰기
Honeytone N-10 Mini Amp Speaker Replacement
필요한 것
  1. Honeytone N-10 Mini Amp Speaker Replacement, Speaker: 1 단계, 이미지 1/2 Honeytone N-10 Mini Amp Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • Flip your amp over to begin removing the plastic cover.
  2. Honeytone N-10 Mini Amp Speaker Replacement: 2 단계, 이미지 1/2 Honeytone N-10 Mini Amp Speaker Replacement: 2 단계, 이미지 2/2
    • Remove the battery cover and take the battery out.
    • Unless you want a quick pick-me-up, in which case feel free to leave it in and get shocked.
  3. Honeytone N-10 Mini Amp Speaker Replacement: 3 단계, 이미지 1/2 Honeytone N-10 Mini Amp Speaker Replacement: 3 단계, 이미지 2/2
    • Unscrew the four corner screws using a phillips #0 screw driver to remove the back cover.
    • While the screws are recessed deep into the cover and difficult to see, 2-4 turns will easily release them.
  4. Honeytone N-10 Mini Amp Speaker Replacement: 4 단계, 이미지 1/3 Honeytone N-10 Mini Amp Speaker Replacement: 4 단계, 이미지 2/3 Honeytone N-10 Mini Amp Speaker Replacement: 4 단계, 이미지 3/3
    • Remove the back cover by carefully pushing the battery connector through the hole in the cover.
  5. Honeytone N-10 Mini Amp Speaker Replacement: 5 단계, 이미지 1/3 Honeytone N-10 Mini Amp Speaker Replacement: 5 단계, 이미지 2/3 Honeytone N-10 Mini Amp Speaker Replacement: 5 단계, 이미지 3/3
    • With the phillips #0 screwdriver, unscrew the two white plastic clips that hold the speaker in place.
  6. Honeytone N-10 Mini Amp Speaker Replacement: 6 단계, 이미지 1/2 Honeytone N-10 Mini Amp Speaker Replacement: 6 단계, 이미지 2/2
    • Use flush wire cutters to remove black and red wires from the old speaker.
    • Note: The black wire has already been removed in this example image.
  7. Honeytone N-10 Mini Amp Speaker Replacement: 7 단계, 이미지 1/3 Honeytone N-10 Mini Amp Speaker Replacement: 7 단계, 이미지 2/3 Honeytone N-10 Mini Amp Speaker Replacement: 7 단계, 이미지 3/3
    • Connect the new speaker by soldering the black and red wires to the negative and positive connections respectively
  8. Honeytone N-10 Mini Amp Speaker Replacement: 8 단계, 이미지 1/1
    • Connect the battery and turn the power on to test proper connection of the new speaker.
    • Some static is fine, this is the natural sound of the amp.
    • Careful not to touch any of the metal components inside while temporarily testing the connection.
  9. Honeytone N-10 Mini Amp Speaker Replacement: 9 단계, 이미지 1/1
    • Reverse steps 1-5 to complete repair.
    • Connect the amp to your favorite instrument and test out the new sound!
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Corey Brown
회원 가입일: 06/24/16
8,682 평판
안내서 11개 작성하였습니다
댓글 한 개
Cool. If mine doesn’t work, is it likely to be the speaker? Thanks.
hupaand - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 16
전체 시간: 3,489
