주요 콘텐츠로 건너뛰기
Honeywell HY-204 Control Panel Replacement
필요한 것
  1. Honeywell HY-204 Control Panel Replacement, Case: 1 단계, 이미지 1/2 Honeywell HY-204 Control Panel Replacement, Case: 1 단계, 이미지 2/2
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Control Panel Replacement: 2 단계, 이미지 1/2 Honeywell HY-204 Control Panel Replacement: 2 단계, 이미지 2/2
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Control Panel Replacement, Control Panel: 3 단계, 이미지 1/2 Honeywell HY-204 Control Panel Replacement, Control Panel: 3 단계, 이미지 2/2
    • Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Control Panel Replacement: 4 단계, 이미지 1/1
    • Pry off the control panel by forcefully lifting the tab located inside the front of the fan with the plastic opening tool.
결론
Nolan Ernotte
회원 가입일: 10/14/14
366 평판
안내서 3개 작성하였습니다
Cal Poly, Team 10-40, Amido Fall 2014 Cal Poly, Team 10-40, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G40
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 527
