소개
After removing the outer casing, replacing the fan blades is quick and easy! You would want to use this guide to replace the broken part or clean dirty blades.
필요한 것
Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
거의 끝나갑니다!
결론
