주요 콘텐츠로 건너뛰기
Honeywell HY-204 Fan Motor Replacement
필요한 것
  1. Honeywell HY-204 Fan Motor Replacement, Case: 1 단계, 이미지 1/2 Honeywell HY-204 Fan Motor Replacement, Case: 1 단계, 이미지 2/2
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Fan Motor Replacement: 2 단계, 이미지 1/2 Honeywell HY-204 Fan Motor Replacement: 2 단계, 이미지 2/2
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Fan Motor Replacement, Fan Blades: 3 단계, 이미지 1/2 Honeywell HY-204 Fan Motor Replacement, Fan Blades: 3 단계, 이미지 2/2
    • Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
    • The nut uses a left-handed thread.
  4. Honeywell HY-204 Fan Motor Replacement: 4 단계, 이미지 1/2 Honeywell HY-204 Fan Motor Replacement: 4 단계, 이미지 2/2
    • Grasp the fan blade firmly and pull upward to remove it from the center column of the fan.
    • The slots on the fan blades and center column need to be aligned for reassembly.
  5. Honeywell HY-204 Fan Motor Replacement, Fan Motor: 5 단계, 이미지 1/2 Honeywell HY-204 Fan Motor Replacement, Fan Motor: 5 단계, 이미지 2/2
    • Remove the four 12.7mm screws using the Phillips #0 Screwdriver.
    • Once the screws are removed, lift the motor off its base.
  6. Honeywell HY-204 Fan Motor Replacement: 6 단계, 이미지 1/2 Honeywell HY-204 Fan Motor Replacement: 6 단계, 이미지 2/2
    • Remove the wire connectors from the black, brown, red, blue, white, grey, and green wires. To do this, grip each wire with your hand and use the pliers to de-crimp the heads of each wire connector by applying pressure to the wider ends of the connector until it falls free.
    • While reassembling, apply pressure to the more narrow ends of the wire connectors to re-crimp them onto the wires.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Armando Jacob Espinoza
회원 가입일: 10/14/14
500 평판
안내서 3개 작성하였습니다
Cal Poly, Team 10-40, Amido Fall 2014 Cal Poly, Team 10-40, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G40
3 회원들
안내서 7개 작성하였습니다
댓글 2개
Where do you purchase the replacement fan motors from?
mattb - 답글
Do you know where I can find the fan motor replacement?
Dave Smith - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 32
전체 시간: 6,277
