소개
This guide will walk you through the removal of your fan motor. It should be fairly easy, although you will need to crimp the wires to remove the motor.
필요한 것
Remove the hex nut from the fan motor with a 10mm hexagonal ratcheting socket wrench.
Remove the four 12.7mm screws using the Phillips #0 Screwdriver.
Once the screws are removed, lift the motor off its base.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
