주요 콘텐츠로 건너뛰기
Honeywell HY-204 Rotation Motor Replacement
필요한 것
  1. Honeywell HY-204 Rotation Motor Replacement, Rotation Motor: 1 단계, 이미지 1/1
    • Before you begin, be sure to unplug the fan.
    • Lay fan on the ground and use your fingers peel the three feet off the bottom of the fan.
  2. Honeywell HY-204 Rotation Motor Replacement: 2 단계, 이미지 1/1
    • Remove the three 12mm screws using the Phillips #0 Screwdriver.
  3. Honeywell HY-204 Rotation Motor Replacement: 3 단계, 이미지 1/2 Honeywell HY-204 Rotation Motor Replacement: 3 단계, 이미지 2/2
    • Remove the two 10mm screws using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Rotation Motor Replacement: 4 단계, 이미지 1/1
    • Move the rotation motor left and right to reveal the screw connecting it to the fan.
    • Remove the 18mm screw from the side of the motor using the Phillips #0 Screwdriver.
  5. Honeywell HY-204 Rotation Motor Replacement: 5 단계, 이미지 1/1
    • Using the wire cutters, severe the wires connecting the rotation motor to the fan.
    • To put back together you will need to resolder or use wire connectors to reattach motor.
결론
Armando Jacob Espinoza
회원 가입일: 10/14/14
500 평판
안내서 3개 작성하였습니다
Cal Poly, Team 10-40, Amido Fall 2014 Cal Poly, Team 10-40, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G40
3 회원들
안내서 7개 작성하였습니다
댓글 2개
It seems that these instructions are on “How to eeplacr the oscillation motor". But they neglect the requirement to have a replacement motor or how/where to get the replacement motor. Otherwise the steps seem clear.
Alan A. Kopta - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 16
전체 시간: 2,683
