주요 콘텐츠로 건너뛰기
Honeywell HY-254-TGT Fan Blade Replacement
필요한 것
  1. Honeywell HY-254-TGT Fan Blade Replacement, Plastic Assembly: 1 단계, 이미지 1개 중 1개
    • Remove the two 3/4" wing screws on the bottom of the fan by rotating them counter-clockwise.
  2. Honeywell HY-254-TGT Fan Blade Replacement: 2 단계, 이미지 3개 중 1개 Honeywell HY-254-TGT Fan Blade Replacement: 2 단계, 이미지 3개 중 2개 Honeywell HY-254-TGT Fan Blade Replacement: 2 단계, 이미지 3개 중 3개
    • Twist the fan base counter-clockwise until the pins line up as shown.
    • Pull the base straight towards you to remove it, feeding the wire through the base.
  3. Honeywell HY-254-TGT Fan Blade Replacement: 3 단계, 이미지 1개 중 1개
    • Remove all of the marked 1/2" Phillips #02 screws on the backside of the fan
    • Remove the two marked 3/4" Phillips #02 screws in the middle.
  4. Honeywell HY-254-TGT Fan Blade Replacement: 4 단계, 이미지 3개 중 1개 Honeywell HY-254-TGT Fan Blade Replacement: 4 단계, 이미지 3개 중 2개 Honeywell HY-254-TGT Fan Blade Replacement: 4 단계, 이미지 3개 중 3개
    • Use a plastic opening tool or screwdriver to pry off the back of the fan, starting from the top down.
    • Be aware of two clips inside the fan, towards the bottom third of the fan. If the back appears stuck on certain spots, push inward edges of the front casing around the problematic area.
  5. Honeywell HY-254-TGT Fan Blade Replacement, Fan Blade: 5 단계, 이미지 2개 중 1개 Honeywell HY-254-TGT Fan Blade Replacement, Fan Blade: 5 단계, 이미지 2개 중 2개
    • Unscrew the two 1/2" Phillips #02 screws.
    • Upon doing so, the front panel of the fan can be leaned forward and set down.
    • The front panel is not detached from the body and cannot be completely removed. Do not try to forcefully remove it, as it may cause damage to the electronics.
  6. Honeywell HY-254-TGT Fan Blade Replacement: 6 단계, 이미지 3개 중 1개 Honeywell HY-254-TGT Fan Blade Replacement: 6 단계, 이미지 3개 중 2개 Honeywell HY-254-TGT Fan Blade Replacement: 6 단계, 이미지 3개 중 3개
    • Unscrew the two marked 1/2" Phillips #02 screws on the part holding the fan blade.
    • Slide the plastic fan cap off the fan while holding the fan blade to ensure it comes off smoothly.
  7. Honeywell HY-254-TGT Fan Blade Replacement: 7 단계, 이미지 2개 중 1개 Honeywell HY-254-TGT Fan Blade Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the 1/4" Phillips #02 screw between the fan and the motor, located at the bottom of the fan.
    • You may need to rotate the fan blade to find the screw.
    • Upon reassembly, make sure that the notched part of the motor axle (blue square) lines up with the screw hole on the fan blade.
  8. Honeywell HY-254-TGT Fan Blade Replacement: 8 단계, 이미지 3개 중 1개 Honeywell HY-254-TGT Fan Blade Replacement: 8 단계, 이미지 3개 중 2개 Honeywell HY-254-TGT Fan Blade Replacement: 8 단계, 이미지 3개 중 3개
    • Return back to the top of the fan blade. Lift the fan blade to a slight angle and gently pull it towards you.
    • If the fan blade seems stuck, spin the fan blade back and forth while pulling it towards you.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Mark Schefter
회원 가입일: 09/29/15
218 평판
안내서 1개를 작성함
Cal Poly, Team 11-6, Forte Fall 2015 Cal Poly, Team 11-6, Forte Fall 2015 회원
CPSU-FORTE-F15S11G6
4 회원들
안내서 4개를 작성함
댓글 5개
Do you know where I can find the screw listed in step 7? I have seemed to misplaced it.
krayze1 - 답글
Do you know the part number for the fan blade?
indiwench - 답글
MARK: What is the part number of the long tall round fan blade cylinder filter, so I can order some? I am having GREAT difficulty finding this elusive part ANYWHERE on the good ol’ fashion internet. I have four of these Honeywell HY-254 fans in my home and they all need to have those cylinders replaced. These are GREAT fans, VERY, VERY QUIET and all new models by competitive companies are loud, rickety & poorly made. This version of honetwell, is by far, the BEST! I will stand by to hear from you. Thank you.
Anthony Ochoa - 답글
my fan rotating but no air. After I cleaned the fan it functioned at level 3 only if I turn to level 2 or 1 the fan rotated but I don't feel any air come out from the fan. do you think the problem comes from the motor? do I have to change the motor?
Jamilah Azubir - 답글
Thanks for the great repair guide!
I have a Honeywell HY-254E that looks exactly like the model in this guide. However, I have a problem with two of the screws. In my case the two middling screws that hold the backside of the main case and thatare above described as "3/4" Phillips #02 screws" look like Torx screws.
However, I don't have the right driver and I'm unsure which Torx size I need. Does anyone have an idea which Torx size this could be?
Many thanks in advance!
Chris
Christian Steinert - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 30
전체 시간: 10,968
