주요 콘텐츠로 건너뛰기
Honeywell HY-254-TGT Front Panel Replacement
필요한 것
  1. Honeywell HY-254-TGT Front Panel Replacement, Plastic Assembly: 1 단계, 이미지 1개 중 1개
    • Remove the two 3/4" wing screws on the bottom of the fan by rotating them counter-clockwise.
  2. Honeywell HY-254-TGT Front Panel Replacement: 2 단계, 이미지 3개 중 1개 Honeywell HY-254-TGT Front Panel Replacement: 2 단계, 이미지 3개 중 2개 Honeywell HY-254-TGT Front Panel Replacement: 2 단계, 이미지 3개 중 3개
    • Twist the fan base counter-clockwise until the pins line up as shown.
    • Pull the base straight towards you to remove it, feeding the wire through the base.
  3. Honeywell HY-254-TGT Front Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Remove all of the marked 1/2" Phillips #02 screws on the backside of the fan
    • Remove the two marked 3/4" Phillips #02 screws in the middle.
  4. Honeywell HY-254-TGT Front Panel Replacement: 4 단계, 이미지 3개 중 1개 Honeywell HY-254-TGT Front Panel Replacement: 4 단계, 이미지 3개 중 2개 Honeywell HY-254-TGT Front Panel Replacement: 4 단계, 이미지 3개 중 3개
    • Use a plastic opening tool or screwdriver to pry off the back of the fan, starting from the top down.
    • Be aware of two clips inside the fan, towards the bottom third of the fan. If the back appears stuck on certain spots, push inward edges of the front casing around the problematic area.
  5. Honeywell HY-254-TGT Front Panel Replacement, Front Panel: 5 단계, 이미지 2개 중 1개 Honeywell HY-254-TGT Front Panel Replacement, Front Panel: 5 단계, 이미지 2개 중 2개
    • Remove the four 1/2" Phillips #02 screws, indicated by a red circle.
    • Lean the front panel forwards and set it down.
    • The front panel will not fully detach and cannot be removed. Do not try to forcibly remove it, as it may cause damage to the electronics.
  6. Honeywell HY-254-TGT Front Panel Replacement: 6 단계, 이미지 2개 중 1개 Honeywell HY-254-TGT Front Panel Replacement: 6 단계, 이미지 2개 중 2개
    • Gently lift and remove the panel covering the electronics assembly.
  7. Honeywell HY-254-TGT Front Panel Replacement: 7 단계, 이미지 3개 중 1개 Honeywell HY-254-TGT Front Panel Replacement: 7 단계, 이미지 3개 중 2개 Honeywell HY-254-TGT Front Panel Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the four 1/2" Phillips #01 screws in the circuit board.
    • Gently pull the circuit board off of the rest of the front panel assembly.
  8. Honeywell HY-254-TGT Front Panel Replacement: 8 단계, 이미지 3개 중 1개 Honeywell HY-254-TGT Front Panel Replacement: 8 단계, 이미지 3개 중 2개 Honeywell HY-254-TGT Front Panel Replacement: 8 단계, 이미지 3개 중 3개
    • Lift out the internal part of the front panel to access the buttons.
  9. Honeywell HY-254-TGT Front Panel Replacement: 9 단계, 이미지 1개 중 1개
    • If necessary, remove the buttons by grabbing them with two fingers and pulling up and away from the panel.
    • Upon reassembly, ensure buttons are placed in the correct location.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Darian Maxwell
회원 가입일: 10/01/15
381 평판
안내서 2개를 작성함
Cal Poly, Team 11-6, Forte Fall 2015 Cal Poly, Team 11-6, Forte Fall 2015 회원
CPSU-FORTE-F15S11G6
4 회원들
안내서 4개를 작성함
댓글 2개
the piece to make it turn is broken
clara rojas - 답글
the piece that make it turn is broken!
clara rojas - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 7
전체 시간: 5,533
