주요 콘텐츠로 건너뛰기
Honeywell HYF260BV2 Main Board Replacement
필요한 것
  1. Honeywell HYF260BV2 Main Board Replacement, Main Board: 1 단계, 이미지 2개 중 1개 Honeywell HYF260BV2 Main Board Replacement, Main Board: 1 단계, 이미지 2개 중 2개
    • Unplug your fan and place it on its side.
    • Twist the red plastic piece off from the bottom.
    • Carefully detach the base from the fan to expose the screws located at the bottom of the fan.
  2. Honeywell HYF260BV2 Main Board Replacement: 2 단계, 이미지 3개 중 1개 Honeywell HYF260BV2 Main Board Replacement: 2 단계, 이미지 3개 중 2개 Honeywell HYF260BV2 Main Board Replacement: 2 단계, 이미지 3개 중 3개
    • Use a TORX Security TR15 screwdriver to unscrew the three 12 mm screws near the bottom of the fan.
  3. Honeywell HYF260BV2 Main Board Replacement: 3 단계, 이미지 3개 중 1개 Honeywell HYF260BV2 Main Board Replacement: 3 단계, 이미지 3개 중 2개 Honeywell HYF260BV2 Main Board Replacement: 3 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove four 12 mm screws on the head of the fan.
  4. Honeywell HYF260BV2 Main Board Replacement: 4 단계, 이미지 3개 중 1개 Honeywell HYF260BV2 Main Board Replacement: 4 단계, 이미지 3개 중 2개 Honeywell HYF260BV2 Main Board Replacement: 4 단계, 이미지 3개 중 3개
    • Use a heavy-duty spudger or opening tool to release the tabs securing the front and back of the fan, then gently pry them apart.
    • Do this gently because you could break the connectors for the back of the fan.
  5. Honeywell HYF260BV2 Main Board Replacement: 5 단계, 이미지 1개 중 1개
    • Pull off the back of the fan and set it aside.
    • Dust the inside of the fan if it is needed.
    • Be careful when dusting and ensure nothing is knocked out of place.
  6. Honeywell HYF260BV2 Main Board Replacement: 6 단계, 이미지 3개 중 1개 Honeywell HYF260BV2 Main Board Replacement: 6 단계, 이미지 3개 중 2개 Honeywell HYF260BV2 Main Board Replacement: 6 단계, 이미지 3개 중 3개
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws at the head of the fan.
    • Remove the two larger 14 mm Phillips #1 screws located below.
    • Remove the two 10 mm Phillips #1 screws located between the 14 mm screws.
  7. Honeywell HYF260BV2 Main Board Replacement: 7 단계, 이미지 1개 중 1개
    • Pull the gray cover from the fan to reveal the main board.
  8. Honeywell HYF260BV2 Main Board Replacement: 8 단계, 이미지 1개 중 1개
    • Carefully hold the edges of the main board and slowly pull it out.
  9. Honeywell HYF260BV2 Main Board Replacement: 9 단계, 이미지 2개 중 1개 Honeywell HYF260BV2 Main Board Replacement: 9 단계, 이미지 2개 중 2개
    • Unplug the main board.
    • Follow the cables connected to the board to the bottom of the fan.
  10. Honeywell HYF260BV2 Main Board Replacement: 10 단계, 이미지 2개 중 1개 Honeywell HYF260BV2 Main Board Replacement: 10 단계, 이미지 2개 중 2개
    • Unplug the connector to disconnect the bundle of wires.
    • Use scissors to cut the zip tie that secures the wires.
    • Be careful when you cut the zip tie so that you don't accidentally cut the wires.
  11. Honeywell HYF260BV2 Main Board Replacement: 11 단계, 이미지 1개 중 1개
    • Pull the wires up and slide them out of the fan to replace the main board with a new one.
결론
작성자
1다른 기여자 명과 함께
Joshua Moreno
회원 가입일: 10/16/24
193 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 23
전체 시간: 285
