주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement
필요한 것
  1. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement, Electrochemical Sensors: 1 단계, 이미지 1개 중 1개
    • Confirm which sensor you are intending to replace. Make note of it.
    • Nitrile gloves should be worn for the entire procedure.
    댓글 쓰기
  2. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: 2 단계, 이미지 2개 중 1개 Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: 2 단계, 이미지 2개 중 2개
    • Place the monitor face down on a clean surface.
    • Use the Phillips #0 screwdriver to remove the single 3 mm Phillips screw on the belt clip.
    댓글 쓰기
  3. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: 3 단계, 이미지 1개 중 1개
    • Starting at the bottom of the case, pull the outer case away from the main body of the monitor.
    • Continue pulling out and away until the entire outer case has been removed.
    댓글 쓰기
  4. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: 4 단계, 이미지 1개 중 1개
    • With the Phillips #0 screwdriver, remove all four 3 mm screws from the rear pump/sensor cover.
    댓글 쓰기
  5. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the outer pump/sensor housing cover and set it aside.
    댓글 쓰기
  6. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully grip and twist the outer edge of the sensor to remove the sensor from its insertion point.
    • Be careful not to twist too aggressively as this could damage the sensor attachment point in the monitor.
    댓글 쓰기
  7. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: 7 단계, 이미지 3개 중 1개 Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: 7 단계, 이미지 3개 중 2개 Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: 7 단계, 이미지 3개 중 3개
    • Grip the replacement sensor on the outer edge.
    • Insert the new sensor in a straight downward orientation.
    • Be careful to line up the prongs with their insertion/attachment point in the monitor.
    댓글 쓰기
  8. Honeywell MultiRae Hydrogen Sulfide Electrochemical Sensors Replacement: 8 단계, 이미지 1개 중 1개
    • Reassemble the unit in reverse order.
    • After reassembly, power the unit on to ensure that the monitor recognizes the new sensor.
    • Calibrate the sensor per the manufacturer's instructions.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Steven E Boughey
회원 가입일: 01/04/21
221 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 28
지난 30일: 121
전체 시간: 3,227
