주요 콘텐츠로 건너뛰기
Honeywell Turbo Force Air Circulator Fan Disassembly
필요한 것
  1. Honeywell Turbo Force Air Circulator Fan Disassembly, Overview: 1 단계, 이미지 2개 중 1개 Honeywell Turbo Force Air Circulator Fan Disassembly, Overview: 1 단계, 이미지 2개 중 2개
    • Honeywell Turbo Force 12" Air Circulator.
    • Dimensions - 11.22" x 9.8" x 13.98", 5.7 lbs.
  2. Honeywell Turbo Force Air Circulator Fan Disassembly, Removing Screws: 2 단계, 이미지 3개 중 1개 Honeywell Turbo Force Air Circulator Fan Disassembly, Removing Screws: 2 단계, 이미지 3개 중 2개 Honeywell Turbo Force Air Circulator Fan Disassembly, Removing Screws: 2 단계, 이미지 3개 중 3개
    • Remove the 6 screws from the backside of the fan.
    • You will want a Phillips screwdriver with a fairly long, thin shaft for this step, especially for the screw up top above the fan speed knob. The screws are recessed several inches into the body of the fan.
  3. Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the grill: 3 단계, 이미지 2개 중 1개 Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the grill: 3 단계, 이미지 2개 중 2개
    • Remove the front grill cover.
  4. Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the plastic ring: 4 단계, 이미지 2개 중 1개 Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the plastic ring: 4 단계, 이미지 2개 중 2개
    • Remove the inside plastic ring around center shaft.
    • Enables the fan blades to be removed.
    • Use a flat head screwdriver to remove the plastic ring.
    • During reassembly, you will likely need to apply pressure on two opposite sides of the ring in order for it to re-mount to the post properly. Ensure that the raised convex side is facing towards you.
  5. Honeywell Turbo Force Air Circulator Fan Disassembly, Removing Fan blades: 5 단계, 이미지 2개 중 1개 Honeywell Turbo Force Air Circulator Fan Disassembly, Removing Fan blades: 5 단계, 이미지 2개 중 2개
    • Remove the fan blades by pulling.
  6. Honeywell Turbo Force Air Circulator Fan Disassembly, Detaching wire covering: 6 단계, 이미지 2개 중 1개 Honeywell Turbo Force Air Circulator Fan Disassembly, Detaching wire covering: 6 단계, 이미지 2개 중 2개
    • Remove 1 screw inside to detach the plastic wire covering.
  7. Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the wire protector piece: 7 단계, 이미지 1개 중 1개
    • Remove the plastic covering.
  8. Honeywell Turbo Force Air Circulator Fan Disassembly, Unscrewing the motor: 8 단계, 이미지 3개 중 1개 Honeywell Turbo Force Air Circulator Fan Disassembly, Unscrewing the motor: 8 단계, 이미지 3개 중 2개 Honeywell Turbo Force Air Circulator Fan Disassembly, Unscrewing the motor: 8 단계, 이미지 3개 중 3개
    • Remove the 2 screws on the motor.
    • This allows the motor to pull away from the housing.
  9. Honeywell Turbo Force Air Circulator Fan Disassembly, Pulling the Motor from the Housing: 9 단계, 이미지 1개 중 1개
    • Pull the motor away from the housing to expose wiring.
    • Use caution to not detach the wiring from the back.
  10. Honeywell Turbo Force Air Circulator Fan Disassembly, Unscrewing the Rotor: 10 단계, 이미지 2개 중 1개 Honeywell Turbo Force Air Circulator Fan Disassembly, Unscrewing the Rotor: 10 단계, 이미지 2개 중 2개
    • Remove the two screws from the back of the motor.
    • Allows the rotor and front/back bearings to be removed.
  11. Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the Rotor: 11 단계, 이미지 2개 중 1개 Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the Rotor: 11 단계, 이미지 2개 중 2개
    • Remove the rotor and front bearings by pulling.
  12. Honeywell Turbo Force Air Circulator Fan Disassembly, Realigning the Bearings: 12 단계, 이미지 3개 중 1개 Honeywell Turbo Force Air Circulator Fan Disassembly, Realigning the Bearings: 12 단계, 이미지 3개 중 2개 Honeywell Turbo Force Air Circulator Fan Disassembly, Realigning the Bearings: 12 단계, 이미지 3개 중 3개
    • During reassembly, re-align the bearings by tapping on the shaft.
결론
To reassemble the fan, follow these instructions in reverse order. Note that Step 12 is an extra step in the reassembly process to follow.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Donovan Williams
회원 가입일: 04/12/22
406 평판
안내서 1개를 작성함
6가이드 댓글
Thank you for the good guide, I saved my fan in the middle of hot weather!
Noah - 답글
I have a Honeywell HF910. I have taken the cover off but there are no screws behind the fan blades. Any suggestions on how to remove the fan blades? Thank you.
Nancy Alexander - 답글
I have a hf710 turbo fan I need the screws can I find out the size of them there the ones holding the cover on
Janet hicks - 답글
Thank You for the detailed guide. I couldn't get the ring off, other than that Perfect.
Paula L Burnett - 답글
I have a Honeywell HF 810 series fan. I’ve watched both your videos on the 800 and 900 series. I have a problem with the front grill releasing. I’ve taken out all 10 screws and been able to loosen it all the way around, forcefully with screw drivers but it won’t release. It is like the motor is attached to the Front/back grill.Help!
Joan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 82
지난 30일: 424
전체 시간: 20,430
