주요 콘텐츠로 건너뛰기
Hoover LiNX Replace The Motor Replacement
필요한 것
  1. Hoover LiNX  Replace The Motor Replacement, Replace The Motor: 1 단계, 이미지 1개 중 1개
    • Detach the rolling assembly from the body by pushing the button found at the base.
  2. Hoover LiNX  Replace The Motor Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the seven 7.5mm Phillips #1 screws from the brush retainer.
  3. Hoover LiNX  Replace The Motor Replacement: 3 단계, 이미지 2개 중 1개 Hoover LiNX  Replace The Motor Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the brush and retainer from the rolling assembly.
    • The brush will need to be disconnected from the belt.
  4. Hoover LiNX  Replace The Motor Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the eight 4mm Phillips #1 screws from the bottom panel.
  5. Hoover LiNX  Replace The Motor Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the bottom panel.
  6. Hoover LiNX  Replace The Motor Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the motor.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sara Vlhova
회원 가입일: 01/25/18
541 평판
안내서 4개를 작성함
USF Tampa, Team S7-G4, Passmore Spring 2018 USF Tampa, Team S7-G4, Passmore Spring 2018 회원
USFT-PASSMORE-S18S7G4
4 회원들
안내서 12개를 작성함
3가이드 댓글
Where does one get a new brush motor?
Brian - 답글
Thank you for the photos! They’ve been helpful as I’m putting my Linx back together and can’t quite remember how the wires go back in the nozzle assembly. When putting the top plate back on, it’s a very tight fit where the top will be pushed up if maligned.
In the elbow part- It looks like the positive lead is on the left in your photo, but it would be helpful if you would add that specification to your step.
Great Job!
Paulie Jeanne - 답글
In my case the (low quality) wires were broken and I had to just replace the wires from the motor to the contact points in the neck.
Paul Vale - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 51
전체 시간: 4,305
