주요 콘텐츠로 건너뛰기
Hoover LiNX The Motherboard Inside The Handle Replacement
필요한 것
  1. Hoover LiNX The Motherboard Inside The Handle  Replacement, Hoover LiNX Handle Teardown: 1 단계, 이미지 1/1
    • Remove the single 15mm Phillips #1 screw from the handle.
  2. Hoover LiNX The Motherboard Inside The Handle  Replacement: 2 단계, 이미지 1/1
    • Remove the handle by pulling it up.
  3. Hoover LiNX The Motherboard Inside The Handle  Replacement: 3 단계, 이미지 1/1
    • Remove two 15mm Phillips #1 screws from the handle.
  4. Hoover LiNX The Motherboard Inside The Handle  Replacement: 4 단계, 이미지 1/2 Hoover LiNX The Motherboard Inside The Handle  Replacement: 4 단계, 이미지 2/2
    • Use a plastic opening tool to carefully pry the black cover off of the handle.
  5. Hoover LiNX The Motherboard Inside The Handle  Replacement: 5 단계, 이미지 1/2 Hoover LiNX The Motherboard Inside The Handle  Replacement: 5 단계, 이미지 2/2
    • Remove five 15mm Phillips #1 black screws from the handle.
  6. Hoover LiNX The Motherboard Inside The Handle  Replacement: 6 단계, 이미지 1/2 Hoover LiNX The Motherboard Inside The Handle  Replacement: 6 단계, 이미지 2/2
    • Remove the silver plastic cover using the plastic opening tool.
  7. Hoover LiNX The Motherboard Inside The Handle  Replacement, The Motherboard Inside The Handle: 7 단계, 이미지 1/1
    • Remove the black rubber cover from the motherboard.
  8. Hoover LiNX The Motherboard Inside The Handle  Replacement: 8 단계, 이미지 1/1
    • Remove two 8mm Phillips #1 screws from the motherboard.
  9. Hoover LiNX The Motherboard Inside The Handle  Replacement: 9 단계, 이미지 1/2 Hoover LiNX The Motherboard Inside The Handle  Replacement: 9 단계, 이미지 2/2
    • Carefully pull the motherboard out with its attached wires.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sara Vlhova
회원 가입일: 01/25/18
541 평판
안내서 4개 작성하였습니다
USF Tampa, Team S7-G4, Passmore Spring 2018 USF Tampa, Team S7-G4, Passmore Spring 2018 회원
USFT-PASSMORE-S18S7G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 889
