주요 콘텐츠로 건너뛰기
Hoover Power Path Pro Advanced Belt Replacement
필요한 것
  1. Hoover Power Path Pro Advanced Belt Replacement, Brush Roller: 1 단계, 이미지 1/2 Hoover Power Path Pro Advanced Belt Replacement, Brush Roller: 1 단계, 이미지 2/2
    • Unplug the vacuum cleaner from the wall outlet before starting. Make sure the water tanks are empty.
    • Lay the cleaner down horizontally with its wheels closest to the floor.
  2. Hoover Power Path Pro Advanced Belt Replacement: 2 단계, 이미지 1/2 Hoover Power Path Pro Advanced Belt Replacement: 2 단계, 이미지 2/2
    • Hold the lower brush roll with both hands and pull outwards until it is detached.
  3. Hoover Power Path Pro Advanced Belt Replacement: 3 단계, 이미지 1/1
    • Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
    • Remove the brush roller.
  4. Hoover Power Path Pro Advanced Belt Replacement, Belt: 4 단계, 이미지 1/1
    • Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
  5. Hoover Power Path Pro Advanced Belt Replacement: 5 단계, 이미지 1/2 Hoover Power Path Pro Advanced Belt Replacement: 5 단계, 이미지 2/2
    • Pull the red handle shown to remove the front suction unit from the cleaner.
  6. Hoover Power Path Pro Advanced Belt Replacement: 6 단계, 이미지 1/1
    • Unscrew the Phillips #2 screw at the bottom of the hose.
  7. Hoover Power Path Pro Advanced Belt Replacement: 7 단계, 이미지 1/2 Hoover Power Path Pro Advanced Belt Replacement: 7 단계, 이미지 2/2
    • Push down on the handle release button. Pull and disconnect the edge of the top cover on the side of the handle release button.
    • Repeat the above step for the "On/Off" button.
    • When pulling the handle release button, make sure the top of the cleaner does not fall.
  8. Hoover Power Path Pro Advanced Belt Replacement: 8 단계, 이미지 1/1
    • Gently grab the belt and pry it off from the rollers.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Jose Andres Gonzalez Valdes
회원 가입일: 01/22/18
682 평판
안내서 5개 작성하였습니다
Cal Poly, Team S16-G5, Banghart Winter 2018 Cal Poly, Team S16-G5, Banghart Winter 2018 회원
CPSU-BANGHART-W18S16G5
5 회원들
안내서 15개 작성하였습니다
댓글 5개
Who the heck made this so hard,
Roy Merlino - 답글
Day 5 and 4 people, I still can’t lift the top off to be able to replace belts. Is there a video
Roy Merlino - 답글
Just understand there are more screws to remove then what is described in these 8 steps. Once you removed ALL the screws then the plastic lid comes right off.
Neil Sullivan - 답글
How the back do you put the too belts on and seeing how the bag came with two and both were wide what size is the one that goes around the roller the other one control the circle brushes this is one of the most difficult belt change I've bad and I'm counting on car to
Loretta Staley - 답글
There is only 8 screws you need to remove. The diagram makes it hard to know but there are two top ones Directly under the brush ! Once you get them out then comes off no problem at all.
Chris Harnish - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 41
전체 시간: 10,758
