이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The belt on the Hoover Power Path Pro Advanced allows the brush rolls to spin while the power is on. If the brush rolls are not spinning, then it is likely that the brush rolls need to be replaced.
필요한 것
다른 6명이 해당 안내서를 완성하였습니다.
댓글 5개
Who the heck made this so hard,
Day 5 and 4 people, I still can’t lift the top off to be able to replace belts. Is there a video
Just understand there are more screws to remove then what is described in these 8 steps. Once you removed ALL the screws then the plastic lid comes right off.
How the back do you put the too belts on and seeing how the bag came with two and both were wide what size is the one that goes around the roller the other one control the circle brushes this is one of the most difficult belt change I've bad and I'm counting on car to
There is only 8 screws you need to remove. The diagram makes it hard to know but there are two top ones Directly under the brush ! Once you get them out then comes off no problem at all.
