주요 콘텐츠로 건너뛰기
Hoover Power Path Pro Advanced Brush Roller Replacement
필요한 것
  1. Hoover Power Path Pro Advanced Brush Roller Replacement, Brush Roller: 1 단계, 이미지 1/2 Hoover Power Path Pro Advanced Brush Roller Replacement, Brush Roller: 1 단계, 이미지 2/2
    • Unplug the vacuum cleaner from the wall outlet before starting. Make sure the water tanks are empty.
    • Lay the cleaner down horizontally with its wheels closest to the floor.
  2. Hoover Power Path Pro Advanced Brush Roller Replacement: 2 단계, 이미지 1/2 Hoover Power Path Pro Advanced Brush Roller Replacement: 2 단계, 이미지 2/2
    • Hold the lower brush roll with both hands and pull outwards until it is detached.
  3. Hoover Power Path Pro Advanced Brush Roller Replacement: 3 단계, 이미지 1/1
    • Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
    • Remove the brush roller.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jose Andres Gonzalez Valdes
회원 가입일: 01/22/18
682 평판
안내서 5개 작성하였습니다
Cal Poly, Team S16-G5, Banghart Winter 2018 Cal Poly, Team S16-G5, Banghart Winter 2018 회원
CPSU-BANGHART-W18S16G5
5 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 27
전체 시간: 1,979
