주요 콘텐츠로 건너뛰기
Hoover Power Path Pro Advanced Hose Replacement
필요한 것
  1. Hoover Power Path Pro Advanced Hose Replacement, Brush Roller: 1 단계, 이미지 1/2 Hoover Power Path Pro Advanced Hose Replacement, Brush Roller: 1 단계, 이미지 2/2
    • Unplug the vacuum cleaner from the wall outlet before starting. Make sure the water tanks are empty.
    • Lay the cleaner down horizontally with its wheels closest to the floor.
  2. Hoover Power Path Pro Advanced Hose Replacement: 2 단계, 이미지 1/2 Hoover Power Path Pro Advanced Hose Replacement: 2 단계, 이미지 2/2
    • Hold the lower brush roll with both hands and pull outwards until it is detached.
  3. Hoover Power Path Pro Advanced Hose Replacement: 3 단계, 이미지 1/1
    • Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
    • Remove the brush roller.
  4. Hoover Power Path Pro Advanced Hose Replacement, Hose: 4 단계, 이미지 1/1
    • Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
    • They will also be indicated on the bottom of the vacuum.
  5. Hoover Power Path Pro Advanced Hose Replacement: 5 단계, 이미지 1/2 Hoover Power Path Pro Advanced Hose Replacement: 5 단계, 이미지 2/2
    • Pull the red handle shown to remove the front suction unit from the cleaner.
  6. Hoover Power Path Pro Advanced Hose Replacement: 6 단계, 이미지 1/1
    • Unscrew the Phillips #2 screw at the bottom of the hose.
  7. Hoover Power Path Pro Advanced Hose Replacement: 7 단계, 이미지 1/1
    • Grab the attachment at tip of the hose and unscrew it. Pull outwards on the hose until completely removed.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jose Andres Gonzalez Valdes
회원 가입일: 01/22/18
682 평판
안내서 5개 작성하였습니다
Cal Poly, Team S16-G5, Banghart Winter 2018 Cal Poly, Team S16-G5, Banghart Winter 2018 회원
CPSU-BANGHART-W18S16G5
5 회원들
안내서 15개 작성하였습니다
댓글 4개
Where can I find this replacement hose?
Jennifer - 답글
Complete waste of $$, won’t pick up water unless you apply about 40 lbs of downward force on the %#*@ thing, I tried all the trouble shooting tips, no change, maybe used 3 times. The attachment same thing nada. Basically a toy.
Leigh Robert Smith - 답글
Where can I purchase the lower hose?
Eryk H. - 답글
I've been trying to find the hose for mine for two years now I even called hoover and they tell me it's unavailable maybe I need to find a Hoover scrap yard lol if anyone knows where I can get one please let me know via email at jefferyalger1959@gmail.com
Jeffery Alger - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 11
30일 전: 40
전체 시간: 4,331
