주요 콘텐츠로 건너뛰기
Hoover Power Path Pro Advanced Power Switch Replacement
필요한 것
  1. Hoover Power Path Pro Advanced Power Switch Replacement, Power Switch: 1 단계, 이미지 1/1
    • Remove the lower brushroll from the bottom of the cleaner.
  2. Hoover Power Path Pro Advanced Power Switch Replacement: 2 단계, 이미지 1/1
    • Use a long #2 Philips head to remove the 8 numbered screws on the bottom of the cleaner (They will also be indicated on the bottom of the vacuum).
  3. Hoover Power Path Pro Advanced Power Switch Replacement: 3 단계, 이미지 1/2 Hoover Power Path Pro Advanced Power Switch Replacement: 3 단계, 이미지 2/2
    • Pull the red handle to remove the front suction unit from the cleaner.
  4. Hoover Power Path Pro Advanced Power Switch Replacement: 4 단계, 이미지 1/1
    • Unscrew the hose by using a Phillips #2 to detach it from the top cover of the cleaner.
  5. Hoover Power Path Pro Advanced Power Switch Replacement: 5 단계, 이미지 1/2 Hoover Power Path Pro Advanced Power Switch Replacement: 5 단계, 이미지 2/2
    • Push down on the handle release button. Lift the edge of top cover connected to this button.
    • Repeat the above step for the "On/Off" button.
    • Pull entire top cover off.
    • Caution: when pulling the handle release button, make sure the top of the cleaner does not fall.
  6. Hoover Power Path Pro Advanced Power Switch Replacement: 6 단계, 이미지 1/1
    • Remove the "On/Off" cap by pulling it upwards with caution.
  7. Hoover Power Path Pro Advanced Power Switch Replacement: 7 단계, 이미지 1/1
    • Use a long #2 Philips head to remove the two screws from the arched grey piece.
  8. Hoover Power Path Pro Advanced Power Switch Replacement: 8 단계, 이미지 1/2 Hoover Power Path Pro Advanced Power Switch Replacement: 8 단계, 이미지 2/2
    • Pull out the red power the red power switch.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jose Andres Gonzalez Valdes
회원 가입일: 01/22/18
682 평판
안내서 5개 작성하였습니다
Cal Poly, Team S16-G5, Banghart Winter 2018 Cal Poly, Team S16-G5, Banghart Winter 2018 회원
CPSU-BANGHART-W18S16G5
5 회원들
안내서 15개 작성하였습니다
댓글 3개
What is the part number?
martahayner - 답글
Thanks so much!!
debmccrimm - 답글
you have to test the switch, mine tested ok which led me to the fuse between the motor and switch. It was bad, parts warehouse part # 440004065 does the trick.
frank - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 25
전체 시간: 3,503
