이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Lay the cleaner down horizontally with its wheels closest to the floor.
Hold the lower brush roll with both hands and pull outwards until it is detached.
Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
Remove the brush roller.
Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
Pull the red handle shown to remove the front suction unit from the cleaner.
Push down on the handle release button. Pull and disconnect the edge of the top cover on the side of the handle release button.
Repeat the above step for the "On/Off" button.
Unscrew two screws using Phillips #2 screwdriver.
Detach grey piece from vacuum.
Flip vacuum over and unscrew three screws with a Phillips #2 screwdriver.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
What to do if the motor is still good but the cooling fan on the top of the armature has broken off?
