주요 콘텐츠로 건너뛰기
Hoover Power Scrub FH50150 Brush Replacement
필요한 것
  1. Hoover Power Scrub FH50150 Brush Replacement, Handle Replacement: 1 단계, 이미지 1/2 Hoover Power Scrub FH50150 Brush Replacement, Handle Replacement: 1 단계, 이미지 2/2
    • Push the button on the top of the clean water/solutions tank and pull on the handle below the button simultaneously. The tank should easily swing out.
  2. Hoover Power Scrub FH50150 Brush Replacement: 2 단계, 이미지 1/2 Hoover Power Scrub FH50150 Brush Replacement: 2 단계, 이미지 2/2
    • Using the screwdriver, unscrew both of the screws on the backside of the handle.
  3. Hoover Power Scrub FH50150 Brush Replacement: 3 단계, 이미지 1/1
    • Pull the handle upwards. It should freely slide away from the base of the machine.
  4. Hoover Power Scrub FH50150 Brush Replacement, Water Tank: 4 단계, 이미지 1/1
    • Unlatch the grey switch labeled “Tank Release”.
  5. Hoover Power Scrub FH50150 Brush Replacement: 5 단계, 이미지 1/1
    • Gently pull on the water tank until it releases from the base.
  6. Hoover Power Scrub FH50150 Brush Replacement, Brush: 6 단계, 이미지 1/2 Hoover Power Scrub FH50150 Brush Replacement, Brush: 6 단계, 이미지 2/2
    • With the vacuum laying on its back pull gently on the brush part and wiggle until it pulls out of place. Now the brushes are ready for cleaning.
결론
Logan Brown
회원 가입일: 01/22/18
73 평판
안내서 1개 작성함
Cal Poly, Team S16-G4, Banghart Winter 2018 Cal Poly, Team S16-G4, Banghart Winter 2018 회원
CPSU-BANGHART-W18S16G4
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 15
30일 전: 35
전체 시간: 1,905
