주요 콘텐츠로 건너뛰기
Hoover Presto 2-in-1 Cordless Stick Belt Replacement
필요한 것
  1. Hoover Presto 2-in-1 Cordless Stick Belt Replacement, Belt: 1 단계, 이미지 1/2 Hoover Presto 2-in-1 Cordless Stick Belt Replacement, Belt: 1 단계, 이미지 2/2
    • Press grey release button on stick vacuum to release vacuum head.
  2. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 2 단계, 이미지 1/3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 2 단계, 이미지 2/3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 2 단계, 이미지 3/3
    • Locate the circular black turn switch, which is in the upper right corner of the backside of the vacuum head
    • Using a metal spudger, place the tool in the indent of the circular turn switch and turn it from the left to the right or from the "locked" symbol to the "unlocked" symbol
  3. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 3 단계, 이미지 1/3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 3 단계, 이미지 2/3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 3 단계, 이미지 3/3
    • Flip the vacuum head over so that the wheels and screws are facing you.
    • Using a PH #1 screw driver, remove the four 15mm screws from each corner of the backside of the vacuum head.
  4. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 4 단계, 이미지 1/3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 4 단계, 이미지 2/3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 4 단계, 이미지 3/3
    • Locate the two wheels in the upper half of the vacuum head and remove them by sticking the metal spudger tool underneath the wheel and pushing it towards you until it pops out.
    • Remove the two 15mm screws located underneath the wheels with a PH #1 screw driver.
  5. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 5 단계, 이미지 1/3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 5 단계, 이미지 2/3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 5 단계, 이미지 3/3
    • Using a firm grip, pull the two halves of the vacuum head away from each other until they are completely separated
  6. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 6 단계, 이미지 1/2 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 6 단계, 이미지 2/2
    • Remove the mechanism with your hands.
  7. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 7 단계, 이미지 1/2 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 7 단계, 이미지 2/2
    • Remove the two 7mm screws located on either side of the roller with a PH #1 screw driver.
    • Removing these screws helps loosen the belt so that it is easier to take off the mechanism.
  8. Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 8 단계, 이미지 1/3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 8 단계, 이미지 2/3 Hoover Presto 2-in-1 Cordless Stick Belt Replacement: 8 단계, 이미지 3/3
    • Use a metal spudger to lift the belt away from the mechanism.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
katia zubieta
회원 가입일: 09/11/17
437 평판
안내서 4개 작성하였습니다
CSU Fullerton, Team S2-G6, Bruce Fall 2017 CSU Fullerton, Team S2-G6, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G6
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 18
전체 시간: 812
