주요 콘텐츠로 건너뛰기
Hoover Presto 2-in-1 Cordless Stick Charger Replacement
필요한 것
  1. Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: 1 단계, 이미지 1/3 Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: 1 단계, 이미지 2/3 Hoover Presto 2-in-1 Cordless Stick Charger Replacement, Charger Electronic Module: 1 단계, 이미지 3/3
    • Using a firm grip, gently pull the standing charger away from the floor charger attachment
  2. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 2 단계, 이미지 1/2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 2 단계, 이미지 2/2
    • Flip the floor charger over so the screws and sticker are facing you
    • Using a PH #1 screw driver, remove the two 18mm screws on the right hand side of the floor charger
  3. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 3 단계, 이미지 1/2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 3 단계, 이미지 2/2
    • Using a PH #2 screw driver, remove the three 18mm screws on floor charger.
  4. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 4 단계, 이미지 1/2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 4 단계, 이미지 2/2
    • Using the metal spudger tool, gently lift up the plastic cover in the upper right hand corner of the floor attachment to uncover a hidden screw
    • Remove the 18mm screw in the upper right hand corner with a PH #1 screw driver
  5. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 5 단계, 이미지 1/2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 5 단계, 이미지 2/2
    • Using the metal spudger, gently pry open the two halves of the floor charger
    • Once you have made a larger enough gap between the two halves, use your hands and gently pull the rest of the floor charger apart
  6. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 6 단계, 이미지 1/1
    • Unscrew the two 18mm screws on either side of the white battery cover with a PH #1 screw driver
  7. Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 7 단계, 이미지 1/2 Hoover Presto 2-in-1 Cordless Stick Charger Replacement: 7 단계, 이미지 2/2
    • Using your hands, gently pull apart the two halves of the white battery cover to get to the battery
결론
다른 한 분이 해당 안내서를 완성하였습니다.
katia zubieta
회원 가입일: 09/11/17
437 평판
안내서 4개 작성하였습니다
CSU Fullerton, Team S2-G6, Bruce Fall 2017 CSU Fullerton, Team S2-G6, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G6
3 회원들
안내서 8개 작성하였습니다
댓글 4개
La pila dónde la puedo encontrar
alejandro rodriguez - 답글
De la aspiradora Hoover presto 2 un 1
I followed the directions above and got it opened. There was no battery inside. What do I do???? This is for the Hoover Presto 2in1. Thank you.
silvmarg - 답글
Where does one buy the replacement battery?
mytikikitty - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 22
전체 시간: 6,076
