주요 콘텐츠로 건너뛰기
Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement
  1. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement, HEPA Filter: 1 단계, 이미지 1/3 Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement, HEPA Filter: 1 단계, 이미지 2/3 Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement, HEPA Filter: 1 단계, 이미지 3/3
    • Using your hands, gently pull the hand vacuum away from the stick vacuum to detach.
  2. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: 2 단계, 이미지 1/2 Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: 2 단계, 이미지 2/2
    • Press the hand vacuum's gray release button located directly below the power button to release the dust container from the hand vacuum.
    • Gently pull off the dust container with your other hand.
  3. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: 3 단계, 이미지 1/2 Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: 3 단계, 이미지 2/2
    • Remove HEPA filter from dust pan by pulling gently.
  4. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: 4 단계, 이미지 1/2 Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: 4 단계, 이미지 2/2
    • Separate the cyclonic separator from the HEPA filter by pulling apart.
  5. Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: 5 단계, 이미지 1/2 Hoover Presto 2-in-1 Cordless Stick HEPA Filter Replacement: 5 단계, 이미지 2/2
    • Hold the HEPA dust filter over trash bin and gently shake to clean. Use hands to rub off dirt/dust if necessary.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
katia zubieta
회원 가입일: 09/11/17
437 평판
안내서 4개 작성하였습니다
CSU Fullerton, Team S2-G6, Bruce Fall 2017 CSU Fullerton, Team S2-G6, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G6
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
Necesito bateria hoover presto 2 en 1 14.4v 1400 mah
cpeza - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 18
전체 시간: 666
