주요 콘텐츠로 건너뛰기
Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement
필요한 것
  1. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement, Height Adjustment Wheels: 1 단계, 이미지 1/2 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement, Height Adjustment Wheels: 1 단계, 이미지 2/2
    • Place the vacuum on its back.
    • Push the red switch to the left.
    • The black cover will then pop out. Remove the cover.
  2. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 2 단계, 이미지 1/3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 2 단계, 이미지 2/3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 2 단계, 이미지 3/3
    • Locate the red switch near the head of the vacuum.
    • Push the switch left.
    • This will pop out the plastic base plate. Remove the plate from the vacuum.
  3. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 3 단계, 이미지 1/3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 3 단계, 이미지 2/3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 3 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the screws from the right side of the white plastic frame.
  4. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 4 단계, 이미지 1/3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 4 단계, 이미지 2/3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 4 단계, 이미지 3/3
    • Remove screws from the left side of the white plastic frame.
  5. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 5 단계, 이미지 1/3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 5 단계, 이미지 2/3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 5 단계, 이미지 3/3
    • Pull the white plastic frame away from the vacuum.
    • Slide the vacuum belt off the metal rod.
    • Pull the brush off the vacuum.
  6. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 6 단계, 이미지 1/2 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 6 단계, 이미지 2/2
    • Remove the screws at the bottom of the white frame near the roller.
  7. Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 7 단계, 이미지 1/3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 7 단계, 이미지 2/3 Hoover T-Series WindTunnel Pet UH30310 Height Adjustment Wheels Replacement: 7 단계, 이미지 3/3
    • Pop off the right side of the white frame.
    • Pull down the blue hinge and roller.
    • Pull free the roller from the vacuum.
결론
Nathan Yung
회원 가입일: 01/18/18
241 평판
안내서 2개 작성하였습니다
Cal Poly, Team S12-G4, Banghart Winter 2018 Cal Poly, Team S12-G4, Banghart Winter 2018 회원
CPSU-BANGHART-W18S12G4
5 회원들
안내서 9개 작성하였습니다
댓글 2개
HOOVER 30310 brush roller stops when the handle is released for vacuuming. Begins again when handle raised and locked into upright position.
David Blair - 답글
Hoover wind tunnel three pet quick pass. Roller spins in an upright position (locked handle). Foot pedal tensioner and off works, but will not stay in off position.
Kirk Teichert - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 48
전체 시간: 2,317
