주요 콘텐츠로 건너뛰기
Hoover T-Series WindTunnel Pet UH30310 Inlet Filter Replacement
필요한 것
  1. Hoover T-Series WindTunnel Pet UH30310 Inlet Filter Replacement, Inlet Filter: 1 단계, 이미지 1/2 Hoover T-Series WindTunnel Pet UH30310 Inlet Filter Replacement, Inlet Filter: 1 단계, 이미지 2/2
    • Remove the frame of the vacuum by pinching the tab down and pulling the frame away from the vacuum body.
  2. Hoover T-Series WindTunnel Pet UH30310 Inlet Filter Replacement: 2 단계, 이미지 1/2 Hoover T-Series WindTunnel Pet UH30310 Inlet Filter Replacement: 2 단계, 이미지 2/2
    • Locate the large sieve at the bottom of the vacuum body.
    • Lift off the sieve, separating it from the filter.
  3. Hoover T-Series WindTunnel Pet UH30310 Inlet Filter Replacement: 3 단계, 이미지 1/1
    • Remove the old inlet filter from the vacuum body and replace with the new filter.
결론
Nathan Yung
회원 가입일: 01/18/18
241 평판
안내서 2개 작성하였습니다
Cal Poly, Team S12-G4, Banghart Winter 2018 Cal Poly, Team S12-G4, Banghart Winter 2018 회원
CPSU-BANGHART-W18S12G4
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 11
전체 시간: 356
