주요 콘텐츠로 건너뛰기
Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement
필요한 것
  1. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement, Brush: 1 단계, 이미지 1/2 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement, Brush: 1 단계, 이미지 2/2
    • Place the vacuum on its back.
    • On the bottom right side, push the red lever to the left.
    • Remove the plastic cover.
  2. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 2 단계, 이미지 1/3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 2 단계, 이미지 2/3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 2 단계, 이미지 3/3
    • Grab the red switch under the brush and push left.
    • Then remove the plastic base plate.
  3. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 3 단계, 이미지 1/3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 3 단계, 이미지 2/3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 3 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the two screws on the right side of the brush.
  4. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 4 단계, 이미지 1/3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 4 단계, 이미지 2/3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 4 단계, 이미지 3/3
    • Remove the two screws on the left side of the brush.
  5. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 5 단계, 이미지 1/3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 5 단계, 이미지 2/3 Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement: 5 단계, 이미지 3/3
    • Pull the clear plastic away from the head of the vacuum.
    • Slide the belt off the metal rod with your finger.
    • Pull the brush free.
  6. Hoover T-Series WindTunnel Pet UH30310 Vacuum Belt Replacement, Vacuum Belt: 6 단계, 이미지 1/1
    • Removal of the brush will also remove the belt.
결론
Erik Ingels
회원 가입일: 01/18/18
193 평판
안내서 2개 작성하였습니다
Cal Poly, Team S12-G4, Banghart Winter 2018 Cal Poly, Team S12-G4, Banghart Winter 2018 회원
CPSU-BANGHART-W18S12G4
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 761
