주요 콘텐츠로 건너뛰기
Hoover T-Series WindTunnel Pet UH70102 Belt Replacement
필요한 것
  1. Hoover T-Series WindTunnel Pet UH70102 Belt Replacement, Brush Roll: 1 단계, 이미지 1/3 Hoover T-Series WindTunnel Pet UH70102 Belt Replacement, Brush Roll: 1 단계, 이미지 2/3 Hoover T-Series WindTunnel Pet UH70102 Belt Replacement, Brush Roll: 1 단계, 이미지 3/3
    • Push the red release lever to the right.
    • Turn the red switch counterclockwise.
    • Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
  2. Hoover T-Series WindTunnel Pet UH70102 Belt Replacement: 2 단계, 이미지 1/1
    • Pull the brush roll out of vacuum.
    • Remove the belt from brush roller
  3. Hoover T-Series WindTunnel Pet UH70102 Belt Replacement, Belt: 3 단계, 이미지 1/3 Hoover T-Series WindTunnel Pet UH70102 Belt Replacement, Belt: 3 단계, 이미지 2/3 Hoover T-Series WindTunnel Pet UH70102 Belt Replacement, Belt: 3 단계, 이미지 3/3
    • Remove the belt that's to the right of where the brush roll was by pulling the bottom off of the pin.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sophia Stockburger
회원 가입일: 01/22/18
566 평판
안내서 5개 작성하였습니다
Cal Poly, Team S11-G2, Banghart Winter 2018 Cal Poly, Team S11-G2, Banghart Winter 2018 회원
CPSU-BANGHART-W18S11G2
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 32
전체 시간: 2,489
