주요 콘텐츠로 건너뛰기
Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement
필요한 것
  1. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: 1 단계, 이미지 1/3 Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: 1 단계, 이미지 2/3 Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: 1 단계, 이미지 3/3
    • Push the red release lever to the right.
    • Turn the red switch counterclockwise.
    • Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
  2. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement: 2 단계, 이미지 1/1
    • Pull the brush roll out of vacuum.
    • Remove the belt from brush roller
결론
Sophia Stockburger
회원 가입일: 01/22/18
566 평판
안내서 5개 작성하였습니다
Cal Poly, Team S11-G2, Banghart Winter 2018 Cal Poly, Team S11-G2, Banghart Winter 2018 회원
CPSU-BANGHART-W18S11G2
5 회원들
안내서 9개 작성하였습니다
댓글 3개
When you turn the vacuum on the brush roller works until you release the handle to start vacuuming then the brush roller stops. How do I correct this issue?
Brenda Brenda - 답글
Did you ever get an answer on this issue or figure it out? I am having the same problem!
Val -
Mine does the same thing. I have replaced the belt but that didn’t help
Ann - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 20
전체 시간: 995
