주요 콘텐츠로 건너뛰기
Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement
필요한 것
  1. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement, Primary Air Filter: 1 단계, 이미지 1/1
    • Press button on the top of the dust cup and pull back.
    • Remove dust cup from vacuum
  2. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: 2 단계, 이미지 1/1
    • Pull back on black lever and rotate dust cup lid back.
  3. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: 3 단계, 이미지 1/1
    • Lift up on fabric flap to remove filter from vaccum
    • If you wish to clean the filter rather than replace it, it can be washed under a faucet.
    • If washing the filter, make sure it fully dries out before re-installing.
  4. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement, Dust Cup Assembly: 4 단계, 이미지 1/1
    • Holding onto both the top handle and dust cup body, twist the two components apart following the instructions printed on the back.
  5. Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: 5 단계, 이미지 1/2 Hoover WindTunnel 2 Rewind Dust Cup Assembly Replacement: 5 단계, 이미지 2/2
    • Unscrew the three 4 cm Phillips #3 screws located inside the dust filter compartment to detach the dust filter system.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chino Cruz
회원 가입일: 01/22/18
135 평판
안내서 1개 작성함
Cal Poly, Team S11-G4, Banghart Winter 2018 Cal Poly, Team S11-G4, Banghart Winter 2018 회원
CPSU-BANGHART-W18S11G4
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 57
전체 시간: 4,656
