주요 콘텐츠로 건너뛰기
Hoover WindTunnel 2 Rewind Leaky Hose Replacement
필요한 것
  1. Hoover WindTunnel 2 Rewind Leaky Hose Replacement, Leaky Hose: 1 단계, 이미지 1/1
    • Detach the top of the hose from the device by pressing the release button and pulling up on the hose.
  2. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: 2 단계, 이미지 1/1
    • Remove the other end of the hose by twisting the hose clockwise and pulling it off.
  3. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: 3 단계, 이미지 1/1
    • Firmly insert the larger end of the replacement hose into the upward facing hole in the vacuum.
  4. Hoover WindTunnel 2 Rewind Leaky Hose Replacement: 4 단계, 이미지 1/1
    • Line up the smaller end of the hose and insert it into the downward facing hole.
    • Twist the hose until it locks.
결론
The Hoover Windtunnel 2 Rewind must have a solid and functional hose to work correctly. With this set of instructions, it is easy to replace a leaky hose.
다른 6명이 해당 안내서를 완성하였습니다.
Mickey McGuire
회원 가입일: 01/22/18
253 평판
안내서 1개 작성함
Cal Poly, Team S11-G4, Banghart Winter 2018 Cal Poly, Team S11-G4, Banghart Winter 2018 회원
CPSU-BANGHART-W18S11G4
5 회원들
안내서 10개 작성하였습니다
댓글 6개
Good job, helpful. Thanks!
Celeste Williams-Hughes - 답글
Thanks, I'm stuck in quarantine and can't go out to get mine fixed, so I'm so glad I found this. Especially since it was just my hose being filled to the brim with dog hair!
Taylore Kirk - 답글
Same issue. Easy fix thanks!
mark camirand - 답글
That’s great instructions but it’s not even 8 months old. This has happened from day one!!
Linda Schindler - 답글
How long does it take to cool off and turn back on after removing the clog?
Victoria Tingwall - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 40
30일 전: 144
전체 시간: 27,943
