소개
The primary air filter is in the vacuum's dust cap and prevents dust from being sucked out of the dust cup.
It's designed to be easily cleaned or replaced, so it's a quick process.
If your filter merely needs to be cleaned, you can follow this guide, but instead of replacing the filter you can rinse it under a faucet and reinstall it.
필요한 것
Press button on the top of the dust cup and pull back.
Remove dust cup from vacuum
다른 한 분이 해당 안내서를 완성하였습니다.
