주요 콘텐츠로 건너뛰기
Hoover Windtunnel Air Steerable Upright Belt Replacement
필요한 것
  1. Hoover Windtunnel Air Steerable Upright Belt Replacement, Belt: 1 단계, 이미지 1/3 Hoover Windtunnel Air Steerable Upright Belt Replacement, Belt: 1 단계, 이미지 2/3 Hoover Windtunnel Air Steerable Upright Belt Replacement, Belt: 1 단계, 이미지 3/3
    • Unplug power cord before you begin.
    • Remove the 4 phillips 3/4'' screws.
  2. Hoover Windtunnel Air Steerable Upright Belt Replacement: 2 단계, 이미지 1/2 Hoover Windtunnel Air Steerable Upright Belt Replacement: 2 단계, 이미지 2/2
    • Lift off the plate.
  3. Hoover Windtunnel Air Steerable Upright Belt Replacement: 3 단계, 이미지 1/2 Hoover Windtunnel Air Steerable Upright Belt Replacement: 3 단계, 이미지 2/2
    • Separate the belt from the brush roll.
  4. Hoover Windtunnel Air Steerable Upright Belt Replacement: 4 단계, 이미지 1/3 Hoover Windtunnel Air Steerable Upright Belt Replacement: 4 단계, 이미지 2/3 Hoover Windtunnel Air Steerable Upright Belt Replacement: 4 단계, 이미지 3/3
    • Remove the belt from the gear.
결론
To reassemble your device, follow these steps in reverse order.
Sangmin Jung
회원 가입일: 09/26/17
201 평판
안내서 2개 작성하였습니다
Cal Poly, Team S7-G2, Banghart Fall 2017 Cal Poly, Team S7-G2, Banghart Fall 2017 회원
CPSU-BANGHART-F17S7G2
5 회원들
안내서 14개 작성하였습니다
댓글 한 개
That isn’t the steering belt. That is the agitator belt.
Lynn Brown - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 1,467
