주요 콘텐츠로 건너뛰기
Hoover Windtunnel Air Steerable Upright Brush Roll Replacement
필요한 것
  1. Hoover Windtunnel Air Steerable Upright Brush Roll Replacement, Brush Roll: 1 단계, 이미지 1/3 Hoover Windtunnel Air Steerable Upright Brush Roll Replacement, Brush Roll: 1 단계, 이미지 2/3 Hoover Windtunnel Air Steerable Upright Brush Roll Replacement, Brush Roll: 1 단계, 이미지 3/3
    • Remove the 4 phillips 3/4'' screws that hold the bottom plate.
  2. Hoover Windtunnel Air Steerable Upright Brush Roll Replacement: 2 단계, 이미지 1/2 Hoover Windtunnel Air Steerable Upright Brush Roll Replacement: 2 단계, 이미지 2/2
    • Lift the plate up and off the vacuum head.
  3. Hoover Windtunnel Air Steerable Upright Brush Roll Replacement: 3 단계, 이미지 1/2 Hoover Windtunnel Air Steerable Upright Brush Roll Replacement: 3 단계, 이미지 2/2
    • Pull the brush roll away from the belt and remove the old brush roll.
결론
To reassemble your device, follow these steps in reverse order.
Sangmin Jung
회원 가입일: 09/26/17
201 평판
안내서 2개 작성하였습니다
Cal Poly, Team S7-G2, Banghart Fall 2017 Cal Poly, Team S7-G2, Banghart Fall 2017 회원
CPSU-BANGHART-F17S7G2
5 회원들
안내서 14개 작성하였습니다
댓글 한 개
What I find really frustrating is no one sells the felt bushing that holds the brushroll next to the belt.
Jadon Hicks - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 1,740
