주요 콘텐츠로 건너뛰기
Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement
필요한 것
  1. Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement, HEPA Filter: 1 단계, 이미지 1/2 Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement, HEPA Filter: 1 단계, 이미지 2/2
    • Put the cleaner into the upright position, turn the power off, and unplug the power cord.
  2. Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement: 2 단계, 이미지 1/3 Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement: 2 단계, 이미지 2/3 Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement: 2 단계, 이미지 3/3
    • Remove the dirt cup from the cleaner.
    • The HEPA filter is located under the dirt cup and under where it says HEPA.
    • Twist the top counterclockwise to unlock the cap.
  3. Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement: 3 단계, 이미지 1/2 Hoover Windtunnel Air Steerable Upright HEPA Filter Replacement: 3 단계, 이미지 2/2
    • Lift the HEPA filter out.
    • Tap the filter against the inside of a trashcan to knock out the dirt and debris or replace as necessary.
    • Do not wash the HEPA Filter.
결승점
Spencer Nefores
회원 가입일: 09/26/17
201 평판
안내서 2개 작성하였습니다
Cal Poly, Team S7-G2, Banghart Fall 2017 Cal Poly, Team S7-G2, Banghart Fall 2017 회원
CPSU-BANGHART-F17S7G2
5 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 37
전체 시간: 3,011
