주요 콘텐츠로 건너뛰기
Hoover Windtunnel Air Steerable Upright Motor Assembly Replacement
필요한 것
  1. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: 1 단계, 이미지 1/2 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, HEPA Filter: 1 단계, 이미지 2/2
    • Put the cleaner into the upright position, turn the power off, and unplug the power cord.
  2. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 2 단계, 이미지 1/3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 2 단계, 이미지 2/3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 2 단계, 이미지 3/3
    • Remove the dirt cup from the cleaner.
    • The HEPA filter is located under the dirt cup and under where it says HEPA.
    • Twist the top counterclockwise to unlock the cap.
  3. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 3 단계, 이미지 1/2 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 3 단계, 이미지 2/2
    • Lift the HEPA filter out.
    • Tap the filter against the inside of a trashcan to knock out the dirt and debris or replace as necessary.
    • Do not wash the HEPA Filter.
  4. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: 4 단계, 이미지 1/3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: 4 단계, 이미지 2/3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement, Motor Assembly: 4 단계, 이미지 3/3
    • Remove the 4 retaining screws and remove the filter tray.
    • Screw lengths are approximately 3/4".
  5. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 5 단계, 이미지 1/1
    • Pull the motor housing vertically to dislodge the motor.
  6. Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 6 단계, 이미지 1/3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 6 단계, 이미지 2/3 Hoover Windtunnel Air Steerable Upright Motor Assembly  Replacement: 6 단계, 이미지 3/3
    • Use a plastic spudger or opening tool to press on the small circle and wiggle clips free.
결론
다른 2명이 해당 안내서를 완성하였습니다.
steven hoover
회원 가입일: 09/26/17
257 평판
안내서 2개 작성하였습니다
Cal Poly, Team S7-G2, Banghart Fall 2017 Cal Poly, Team S7-G2, Banghart Fall 2017 회원
CPSU-BANGHART-F17S7G2
5 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 43
전체 시간: 3,979
