주요 콘텐츠로 건너뛰기
Hoover Windtunnel Air Steerable Upright Rinsable and HEPA Filter Replacement
  1. Hoover Windtunnel Air Steerable Upright Rinsable and HEPA Filter Replacement, Rinsable Filter: 1 단계, 이미지 1/1
    • Put the cleaner into the upright position, turn off the power and unplug the power cord.
  2. Hoover Windtunnel Air Steerable Upright Rinsable and HEPA Filter Replacement: 2 단계, 이미지 1/3 Hoover Windtunnel Air Steerable Upright Rinsable and HEPA Filter Replacement: 2 단계, 이미지 2/3 Hoover Windtunnel Air Steerable Upright Rinsable and HEPA Filter Replacement: 2 단계, 이미지 3/3
    • Remove the dirt cup from the cleaner.
    • Twist the top of the dirt cup to open it and reveal the rinsable filter.
  3. Hoover Windtunnel Air Steerable Upright Rinsable and HEPA Filter Replacement: 3 단계, 이미지 1/3 Hoover Windtunnel Air Steerable Upright Rinsable and HEPA Filter Replacement: 3 단계, 이미지 2/3 Hoover Windtunnel Air Steerable Upright Rinsable and HEPA Filter Replacement: 3 단계, 이미지 3/3
    • Remove the rinsable filter from the dirt cup.
    • If the rinsable filter is dirty, rinse it with water for 2 minutes or until the water runs clear.
    • Squeeze out excess water and allow to dry for 24 hours.
    • Never put a wet filter back into the cleaner.
결승점
Spencer Nefores
회원 가입일: 09/26/17
201 평판
안내서 2개 작성하였습니다
Cal Poly, Team S7-G2, Banghart Fall 2017 Cal Poly, Team S7-G2, Banghart Fall 2017 회원
CPSU-BANGHART-F17S7G2
5 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 602
