주요 콘텐츠로 건너뛰기
Hoover Windtunnel Air Steerable Upright Suction Hose Replacement
필요한 것
  1. Hoover Windtunnel Air Steerable Upright Suction Hose Replacement, Suction Hose: 1 단계, 이미지 1/1
    • Turn the power off and unplug the power cord.
    • Set the cleaner in the upright position.
  2. Hoover Windtunnel Air Steerable Upright Suction Hose Replacement: 2 단계, 이미지 1/1
    • Dislodge hose from plastic clips for ease of removal.
  3. Hoover Windtunnel Air Steerable Upright Suction Hose Replacement: 3 단계, 이미지 1/1
    • Press firmly on the hose button and slide hose out.
  4. Hoover Windtunnel Air Steerable Upright Suction Hose Replacement: 4 단계, 이미지 1/3 Hoover Windtunnel Air Steerable Upright Suction Hose Replacement: 4 단계, 이미지 2/3 Hoover Windtunnel Air Steerable Upright Suction Hose Replacement: 4 단계, 이미지 3/3
    • Pull the hose out of the top of the vacuum.
    • The hose is connected to the vacuum handle.
    • The bottom of the hose should come out when the top of the hose is pulled away from the vacuum.
결론
steven hoover
회원 가입일: 09/26/17
257 평판
안내서 2개 작성하였습니다
Cal Poly, Team S7-G2, Banghart Fall 2017 Cal Poly, Team S7-G2, Banghart Fall 2017 회원
CPSU-BANGHART-F17S7G2
5 회원들
안내서 14개 작성하였습니다
댓글 3개
what might my problem be? I will start vacuuming and the noise will change to an almost “air escaping” sound and it loses suction. It will make this sound when the filter is very dirty or when the bag is full.
Currently neither of these two things are applicable but it does it almost immediately after turning on. The sound change seems to be coming from the top of the main unit near the handle.
Mike - 답글
vacuum works hose for cleaning turn on off how to engage hose atachment turn on off
Richard Degrandcourt - 답글
how to turn on hose attachment?
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 47
전체 시간: 5,323
